jct
from start to idle to highway speeds my engine pulsates, think it might be a bad condenser(s) timing is set at 10btdc
That's a good safe method for finding a vac leak.If you have a propane torch like for plumbing solder, turn it on unlit wave it around all gaskets fittings ect. When the engine surges or runs better there is your leak.
Shouldn't he light a match to see into the gas tank first?
