NO. That cover has to fit into a machined blind hole it the bell housing to support that end of the shaft and keep it lined up on the ring gear. Your picture shows that the terminal extention has been removed so you should be good to go. The position the picture was taken is the position it will be in when its mounted. My suggestion would be to get it up in the hole and test run the two wires and see if you've got enough wire length to bring them around to the forward end of the starter body and then back onto the terminals...Both those posts are going to be facing the block as you will see when you test fit. (read dam little room 'tween the block and those terminal posts) You DO NOT want to run those wires over the top of the starter to mount them. Once you do the test fit pull the starter back out and down and mount the wires in the possession they will be in when in the starter is mounted. Unless you've got elf tools and elf fingers to match you do not want to try hooking up those wires when the starter is mounted and bolted in, Jer
