Thank you DaveRe read the AC paragraph Jeff...
This bus is shorter than you think... lots of space up there, just butt ugly.I'm sorry, in all the excitement, I lost track on the a.c. This bus was not equipped with a.c., or it has been removed?
And... .
Wouldn't rooftop units put it over 13'6". And you wouldn't want those units on the lower front roof for all the upper deck passengers to see.
The original A/C was run by a small diesel engine in one of the bays... Is that still there? I'm not too sure about any of that still being useful, but that bay may be where the Whisperer wants to put a generator.Bus has AC Stan ... after conversion the question is will it do the job without some additional, strategically placed BTU's. and yes, one on the lower roof messes with scenery from the Panorama Sky View Ports.
Look around the internet and the split A/C can be bought in 110v or 220v, IDK how low you'll drop her when parked, but a modified floor in a bay might allow the heat from the condensing unit to be blown downward and a pan could be made to direct it out from under the bus (think hood scoop, bolted upside down and the condensing unit laid flat on the floor). I bet this could be done with a big pan and only give up a couple inches of ground clearance.
You might even make something work by rehanging a bay door to be able to kick out and do the job when parked.
If a ducted system is used, the only way I would do it is running through the floor, with a catch trough to control condensate water to several drains... It may not be as efficient, but at least would avoid the ugly profile on the roof.
I don't think that is the case with this bus, the Flexble VL100 (scenic look alike) had the spare tire compartment. That doesn't mean that there isn't a bunch of unused space available.Some of those coaches had a spare tire bay behind the front bumper. If yours has one, maybe that space could be repurposed for a remote condenser.
In any case if you had to use part of a bay, it could be isolated and vented for outside intake and exhaust air for the condenser. The generator requires similar treatment.
This bus, to be really comfortable, needs an HVAC plan that works good sitting still, plugged in to shore power, running on the generator when no shore power is available... and, very important, when driving. Some thought should be given to warming/cooling the driver's area without worrying about cooling the back when in motion.
Hybrids and electric cars are using electric compressors, there may not be a ready made aftermarket system yet, but the idea makes perfect sense for this sort of application... How do you feel about a custom 40v+ DC system? OK, back to more practical, I wonder if something like a roof top unit, could be hung upside down under there and work when driving... those units aren't all that complicated, to reconfigure one might be doable.
You wouldn't just have it at 10% if it was a C would you?
