Found my 300 hurst Broadcast Sheet!
Interior
  1. bobfist
    bobfist Member
    84
    51
    Dec 3, 2016
    sweden
    I found my 300 hurst broadcast sheet
    and im wondering if someone can give me the Fury gt sport exhaust tips part numbers?
    My sheet says exhaust tips left 37 and the right 36
    • Like Like x 2
  2. Slantsix
    Slantsix Well-Known Member FCBO Gold Member
    591
    160
    Oct 26, 2015
    Mikkeli
    Now, get plastic sheet what is for using storage photos. Then put ur sheet into dark place. Or in 1-3 months it turn into brown and brittle as hell. How i know, i forgot 1 of my sheet top of bookshelf.
  3. live4theking
    live4theking Old Man with a Hat
    7,063
    1497
    Nov 24, 2014
    Rockland; Venango County Pennsylvania
    I'm glad you found that. Unfortunately I'm of no help with the part numbers. Someone will be. Other would appreciate if you could scan or post a better picture of it as well.
  4. 69CoronetRT
    69CoronetRT Senior Member
    1,616
    968
    Feb 3, 2013
    The heading says TAIL PIPE. 3404 036-7 are the PNs for the tail pipes ( 70 C body w 440-4 HP) not the tips.
    • Thanks! Thanks! x 1
  5. bobfist
    bobfist Member
    84
    51
    Dec 3, 2016
    sweden
    aha so you cant read if it had the quad tail pipes then?
  6. 69monaco
    69monaco Senior Member
    2,328
    1809
    Feb 1, 2014
    Nijverdal (NL)
    I don,t think on the build sheet......maybe on the window sticker......
  7. bobfist
    bobfist Member
    84
    51
    Dec 3, 2016
    sweden
  8. 69CoronetRT
    1,616
    968
    Feb 3, 2013
    No. The BS doesn't show extensions/tips.
  9. bobfist
    bobfist Member
    84
    51
    Dec 3, 2016
    sweden
    it says undercoat/hood pad
    it has a five in it shall it have undercoat and hood pad then?
  10. 1978 NYB
    1978 NYB Warfighter FCBO Gold Member
    39,024
    10258
    Apr 16, 2011
    Classified
    Nice find!
    Make a ton of color copies of the original.
  11. 69CoronetRT
    1,616
    968
    Feb 3, 2013
    Yes. The car should have whatever was included with J55 for that particular model.
  12. Big_John
    10,828
    5749
    May 21, 2013
    Marcellus, NY
  13. Trace 300 Hurst
    Trace 300 Hurst Active Member
    498
    198
    May 27, 2018
    Ponte Vedra Beach, FL
    Just to dredge this back up regarding the exhaust tips, down in the N-block (Engine Accessories) the BS for my Hurst shows N4"1", which is Dual Exhaust W/O Tips (according to several "decoder" websites). The next square is N42--Exhaust Tips, which on my BS is blank, of course.
    The OP's BS shows a "1"in the N-Dual Exhaust block, meaning his car is a non-tips car.
    As for the Exhaust boxes on the 5th line from the top, my numbers are 17 (left) and 45 (right). Dunno what those mean....part numbers, I guess. Not really important, because they're long gone.
    A fella can burn [waste!!] a lot of time pondering his build sheet. I sure have! :thumbsup:
    • Like Like x 1
  14. Fury Pursuit
    Fury Pursuit Senior Member
    1,415
    1505
    Jun 28, 2014
    The 1970 300/H “A12” package did not include the Sport Fury GT exhaust tips. A customer could order them and have the dealer put them on, but they don’t clear the rear valance so they were not standard on a 300/H.
    • Thanks! Thanks! x 3
    • Like Like x 1
  15. Xavi3r
    Xavi3r Active Member
    319
    120
    May 24, 2014
    France
    thanks for the scan.
    I see you have a pre 200000 version.
    Can you post a pic of the data plate please ?
  16. Trace 300 Hurst
    498
    198
    May 27, 2018
    Thanks, Fury, for that A12 exhaust tip info. I didn’t “think” the 300 H came with tips after searching the entire Interweb for pics, but my recently purchased Hurst did come with **not very pretty** chrome tips installed by the POwner when he did an otherwise nice custom 2 1/2 exhaust in 2005. I plan to remove them soon and go with standard downturns like Chrysler intended. And I have seen a few pics of various chrome tip additions like mine.....not good.
  17. Ed Lewis
    Ed Lewis New Member
    12
    0
    Mar 6, 2019
    Pa
    Depending on weather the car had tips or not, the butterfly shaped tip hanger was mounted "up" or "down" to create clearance for the tips under rear valance
